So I redid how my CB was set up and I went to test my swr reading. When I key my Mic and Turn the knob on the SWR meter labeled “SET” or “ADJUST” the needle doesn't reaches the setting position at the end of its range. Any thoughts or ideas of where to look? I didn't adjust wire length just location and I had tuned before. Could it still set correctly?
Thanks I was able to resolve the issue. I'm guessing I didn't have the meter plugged all the way in. The CB is tucked away, so I was just going off feel.
Make sure the antenna cable is shorted out, Possible something dinged the cable or got wedged in the connector
